Restoration S12 - XortioN
Re: Restoration S12 - XortioN
Messagepar toytoy » Lun Oct 27, 2014 7:48 pm
Du très bon travail encore :tchin:
Messagepar alundra » Lun Oct 27, 2014 10:09 pm
Du travail de titan et merci d'avoir pris le temps pour prendre et poster les vidéos.
Courage!
Messagepar XortioN » Dim Nov 16, 2014 1:44 am
Merci beaucoup!!! :tchin: :tchin: :tchin:
Désollé de mettre le texte en Englais :oops:
After a few weeks of hard work on the engine/tranny, it's finally in!
Some information that might be interesting for other S12 owners getting the CA18DET engine:
I used 300ZX engine mounts which are more rigid (less vibration/engine movement) combined with te S13 engine brackets on the S12 CA18ET subframe. I am using the stock S12 transmission combined with a CA18DET clutch + bearing (90-... not the pre 90!!!). Engine does sit a bit higher which makes the engine rub agains the hood, so I will probably be using hood spacers and search for a GP hood :)
Brake lines are kinda close to the exhaust and I had to remove the original heath-shield because the exhaust was stuck against it, I will be making a custom heath shield to resolve this issue.
I used S13 steering pump but used the return line of the S12 steering pump, which made it easier to fit the return line.
Setup:
- CA18DET
- CA18ET gearbox
- 300ZX engine mounts + s13 engine brackets
- T28 turbo
- XS power exhaust manifold
What I also did:
- Give the drive shaft some fresh pain
- New clutch
- New brake lines to the rear
- New gasoline-lines
- And ofcourse a lot of engine stuff :)
To the point, pictures:
XortioN
Messagepar Denrée » Dim Nov 16, 2014 12:55 pm
Super propre comme d'habitude, bientôt le premier démarrage ! ;)
Messagepar alundra » Dim Nov 16, 2014 1:59 pm
Clinical! :sol:
Did you rebuild the engine or the trans?
Messagepar XortioN » Dim Nov 16, 2014 3:15 pm
Merci! Oui le premier démarrage se rapproche :jap:
J'ai complètement reconstrué le moteur:
- Cilinder Hone
- les canaux d'huile ont été fourré et nettoyés
- "The head was flattened" et entièrement révisé
- les couvercles de soupape ont été sablé et "powdercoated"
- le pompe à huile a été révisé
- Nouvelle pompe à eau
- Nouveaux joints
- Nouvelles coussinets principales et coussinets de tête (ACL Duraglide)
- Nouveaux boulons de tête
- Nouveaux tuyaux en silicone
- Nouveaux Anneaux de piston et New racleur d'huile
- Nouveaux distribution
- T28 révisé
- Nouveaux lignes flexibles pour le turbo
- Nouveaux embrayage
- La Boîte a été rincé
Donc j'espere qu'il est presque comme neuve :tchin:
XortioN
Messagepar toytoy » Dim Nov 16, 2014 6:38 pm
on peut le dire oui :chwal:
Messagepar XortioN » Lun Juin 29, 2015 11:15 am
Apres 3 mois de répas (a cause du déménagement de la s12), je suis de nouveau lancé depuis 2 mois.
Le moment de premiere démarrage se rapproche (j'espere que je peux le fair en juillet). Et puis je peux commencer avec la preparation pour la peinture. :sol:
Ce qui est passé:
- Derouillé la réservoir d'essence (je l'ai rempli avec vinaigre depuis 3 semaines) et puis je l'ai traiter avec un epoxy
- Walbro LPH255
- Tous les silicones pour le vide et refroidissement
- K&N intake
- Volvo 740 intercooler
(J'ai du chercer beauuuucoup pour un intercooler qui s'installe avant le radiateur sans modifié le chassis de la s12).
- Toyota AE86 aftermarket radiateur
Et beacoup d'autre trucs ...
Ce qui je dois encore faire pour démarrer
- montage de la réservoir d'essence
- l'échappement
- les ventilateurs
- le cablagge
J'ai aussi trouvé un photo du moment que je l'ai acheter (2-3 ans)
XortioN
Messagepar GoSP » Lun Juin 29, 2015 1:06 pm
Thanks for the update !
Awesome job as usual. Very nice idea to combine the AE86 radiator with the Volvo intercooler ! Giving me some ideas !
Messagepar kohshin » Mar Juin 30, 2015 11:05 am
c'est vrai que c'est la première fois que j'entends parler d'une installation de radiateur d'AE86
Messagepar Uranium_88 » Ven Juil 17, 2015 1:26 am
Een andere S12 in Belgie? Wat voor een tof informatie voor mij ! :tchin: :chwal:
Uranium_88
Véhicule: Nissan Silvia S12
Messagepar Nismos12GP » Ven Juil 24, 2015 8:27 am
Super travail, gros respect pour toi et pour ce projet :jap: je me réjouis de voir le résultat final, esthétiquement elle ressemblera à la mienne :tchin:
Nismos12GP
Messagepar XortioN » Jeu Aoû 06, 2015 12:10 am
Merci tout le monde!! J'ai continué a travailler pour demarrer le S12 et aujourd'hui la premiere était un fait
www.youtube.com/watch?v=XBjTqBF4-bc
La semaine passé j'ai aussi aller en Angleterre et j'ai acheter le front d'un S12 MK2 (j'aime bien le capot et c'est mieux pour le moteur). Et aussi une extra boite et des autres pieces.
La différence entre le MK1 et MK2
mk1
mk2
XortioN
Messagepar Denrée » Ven Aoû 07, 2015 7:05 am
Félicitation pour le premier démarrage ! C'est toujours un grand moment !
Messagepar XortioN » Mer Déc 09, 2015 10:55 pm
So a lot has happened since my last update, but mostly finishing everything. Also pained the interior, rear panels (GP kit comes on top of this), wheel arches and made an exhaust.
Exhaust is made from some pipework and spoon style exhaust (Honda :sol: ).
polished
Interior
Car will be going in for paint and GP kit next weekend :tchin: :tchin: :tchin:
XortioN
Messagepar toytoy » Jeu Déc 10, 2015 8:43 am
Bon boulot comme d'habitude !! :tchin:
Messagepar seb.racing » Jeu Déc 10, 2015 5:49 pm
très bon travail :tchin: :sol:
Messagepar larchy » Jeu Déc 10, 2015 5:54 pm
:love:
une s12 sortie de concession :!:
Qui vivra verra . Vu!
larchy
Messagepar GoSP » Ven Déc 11, 2015 9:50 am
Amazing job ! Can't wait to see her on the road !
Messagepar XortioN » Dim Avr 24, 2016 1:39 pm
Un update apres 6 moins :ddr555: :mrgreen:
Le s12 est presque pret pour la peinture:
- Rouille d'antenne, fenetre, coufre a été remplacé
- Un dent dans le flanc a été reparé
- le MK2 lip a été adapté pour le GP kit et MK1 pare-shocs
- le GP kit a été adapté, cétait beaucoup de travail parce-que le kit n'est pas de bonne qualité. On a choissis pour un systeme avec des allen vises (comme rocket bunny) parce-que c'est mieux pour l'apparition de fissures et en plus je peux les demonter pour laver la voiture derrière les penaux. Le kit a aussi été renforcé .
Donc les photos
Le systeme avec les vises et le bonne fitment apres les adaptions
Et une image avec photoshop:
XortioN
Messagepar Denrée » Lun Avr 25, 2016 9:14 am
Tu va avoir une voiture unique ! Très beau travail !
Messagepar larchy » Lun Avr 25, 2016 9:52 am
tres tres beaux !!
je suis fan :love: :love: :love:
larchy
Messagepar seb.racing » Sam Avr 30, 2016 11:41 am
elle a de la gueule :sol:
Normalement le kit GP prend l'aile complète??
Messagepar XortioN » Ven Mai 06, 2016 11:44 am
Merci!
Oui, tu as raison. Normalement le kit GP prend l'aile complète mais le problème avec ca c'est que le fitment n'est pas parfait et ca peut commencer à déchirer apres quelques ans. Et tu as aussi l'aventage que tu peux laver la voiture sous les paneaux. En plus je trouve que le kit avec des vises c'est 'cool' et 'racy' donc j'aime bien le look. :jap: :D
XortioN
Messagepar seb.racing » Sam Mai 07, 2016 11:26 am
XortioN a écrit:Merci!
le kit GP est aussi fragile que ça? c'est dommage
mais je la trouve très belle, cette modification du kit est vraiment top :sol:
Messagepar XortioN » Dim Mai 08, 2016 12:00 pm
C'est a dire le kit GP qui est un reproduction d'un original n'est pas de bonne qualité. Le kit a eux beaucoup d'adaptions pour un fitment parfait et il est renforcé avec plusiers "layers" de polyester.
Le kit original est plus fort je pense mais c'est pas simple de trouver. Mais aussi avec ce kit La rouille peux former au dessus du kit. J'ai hesiter beaucoup mais je suis heureux que j'ai choissis cette methode. :D
Oooooh je ne peux plus patienter, je veux rouler avec le s12 :chwal:
XortioN
Messagepar lolo » Mar Aoû 09, 2016 3:42 pm
Bonjour, à tu avancé sur ton projet ? De nouvelles photos peut être ?
Un grand bravo pour ta restauration, il fallait du courage...
>>VERY NICE PROJECT<<
lolo
Véhicule: S12 GP
Messagepar XortioN » Mer Jan 25, 2017 11:36 pm
La peinture est presque fini, déjà une photo :)
XortioN
Messagepar alundra » Jeu Jan 26, 2017 4:10 pm
:love:
Messagepar toytoy » Ven Mar 17, 2017 10:55 pm
des nouvelles fraîches Xortion ? :D
:chwal: :tchin:
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 30 invités
